1998 sl2
Hi my 1.9 twin gave me a hard time last night when you start it I had to push gas peddle to floor then it was like it was flooded.Once it was going as long as I kept the idle up and not let the gas off or stop the car runs when starting the car it wont start like it floods wright away.
Have you looked at your engine coolant temperature sensor, it usually cracks and causes starting and running problems. Its resin tipped and the replacement is brass while the two-wire connector being corroded needs replacement too, from a junk yard air temp sensor or the dealer's $30 stock. Check out these picture procedures; http://www.saturnfans.com/forums/showthread.php?t=37884
No I haven't but I will And thank you for your info especially pics this site is great I have only owned the saturn 5 months.Actually thanks to everybody who replied this is awesome this will save me lots if $ if I could avoid garage I'm a do it yourself kind of guy would have tried many things before giving my money to garage.Thanks again. Roger
