auto trans question
if the transmission jerks or bang when put in reverse, then the reverse clutch needs to be tightened, if it bangs through all the geras or any beside reverse, then it needs a new control module. if either of these are the problem, then don't replace the transmission.
92-98 are interchangeable... 91's have a different mounting style, but can still be used.
Go to http://www.differentracing.com/tech_...gearratio.html
Those are the different gear ratios used. Check them out.
