need 2 fix water pump on 92 sc dohc
<DIV id=post_message_605730>Lift the car up on jack stands, remove the passenger side wheel and splash guards. Put the jack under the oil pan and put enough tension to support the engine without lifting it. Then remove the upper mount and lower dogbone mount. Now you can lift the engine up and down with the jack to gain access to all the bolts. Drop the engine to get access to the pulley bolts. Its much easier to remove these with an impact gun, but can be done by either leaving the belt on or using a strap wrench. The bottom bolts of the pump can be easily reached by lowering the engine all the way, and the top bolts by lifting the engine all the way.
Replacement shouldn't really take more than a half hour to 45 minutes.</DIV>Edited by: Low Saturn
Originally Posted by anthonf
If your saturn water pump uses "O" rings instead of gaskets, do not use silicone. Just remember to clean up ALL the surfaces that the rings will seal against. This will avoid leaks when you finish. <STRoNG style="FONT-WEIGHT: normal">Always use the right torque settings when installing anything with a gasket. If you over tighten, you can wreck the gasket before you even start the car. If it’s not tight enough, you’ll get leaks.[/b]
The Saturn water pump uses a preformed silicone gasket.
