Short Throw Shifter?
I was thinking about short shifting my car but I don't know how to do it exactly. If anyone can help by giving some advice or by making one for me lol.
Im in the process of doing this, im just cutting the shifter. I did it on another shifter i had from the junk-yard but I cant put it in since the boot clips are broken and it would look fugly.
Maybe get a junkyard shifter as well so if you mess up youll still have a shifter
Ill let you know how well it works, although I wont get to do it for abit
Just cutting the shaft of the shifter will not make a ( short throw shifter). All that will do is change the hight of your shift ****, and with less leverage it might even be harder to shift. Looking at my Astra being front wheel drive I'm not sure how they would make a true short throw for it. Id like to have one for my car.
Ok well by cutting your shifter that will not make a short throw shifter. All it will do is lower your shift ****. I'm new to saturns but by no means new to cars. So I'm assuming the concept of a short throw shifter will be the same for most cars. For a "short throw shifter" what they actually do is lengthen the "throw part" of the shifter. Therefor making the actual lenght that the shifter **** travels shorter. I'll try and do some research to try and explain myself a little better and get back to you.
I know how it works, however the top half of the shifter on the s-series is ridiculously long in my opinion, so cutting it will help either way, even if it doesn't make shifts shorter it makes them less sloppy since there is alot of play in these shifters..
Unfortunately they dont exist anymore for these cars (and apperently they really never did), or your very, very good at searching, or you make it yourself.
Im doing some digging and looking for instructions.
http://www.saturnspot.com/showthread.php?t=25474
These guys claim to make a short throw, however in the picture it looks like a stock shifter.
I've emailed them to see if I can get some more pictures and information.
http://www.villagemachiningservice.com/page04.html
