start and die help!!!
Originally Posted by Low Saturn
Did you roll your SC1?
Sounds like a problem with the idle air bypass valve being stuck closed. It is easy to replace and cost around $75. It is screwed into the side of the throttle body, is about 1" in diameter and has a 3 wire connector. The throttle body sits on top of the engine and is where the air enters the engine. Go to the parts store and buy the new one and you'll know what it looks like.
____________________
My blogs "My Car Tool Kit"
jcoll72305
01-24-2013 10:45 AM
ryankhemraj
11-01-2010 11:26 PM
