Tensioner Problem
Old 08-13-2008 | 12:02 AM
awilliams7's Avatar
I have a ''99 Saturn SC2 and recently it was making a squeaking noise which I found out was the belt, I replaced the belt because it was really loose, now I think the tensioner is the problem and I don''t know if it is broken and need a new one or it just needs to be tightened. Does anyone know the best way to fix this or had a similar problem?
Old 08-13-2008 | 10:21 AM
Low Saturn's Avatar
You cant tighten the tensioner. If the spring inside is broken or worn, replace the tensioner.
gnccracer
01-02-2009 06:17 PM
KCKIM
11-28-2008 09:09 AM
rabobanks
10-11-2007 11:31 AM
mfunk49
02-01-2007 07:24 PM
02-25-2006 11:28 AM
