01 SL2 - service engine light
Old 01-14-2008 | 05:20 PM
snogo67's Avatar
I have a 2001 SL2 with 138,000 miles. Some days the car runs great, and other days I receive an idiot light (service engine soon). When the light is on, the only code I get is a camshaft position sensor warning. It runs rough (idles irregular) when the light is on, but if and when the light goes out, it idles fine. I have cleaned the ERG, install new plugs and wires, and it has a fresh oil change with new filter. I think it may be the O2 sensor, air idle control, or maybe clugged fuel injectors. But why no code? Any other ideas would be greatly appreciated. Thanks....Ron
Edited by: sw2cam
Old 01-14-2008 | 10:15 PM
Low Saturn's Avatar
Check for corrosion where the ignition module contacts the transmission bell housing.
Another possible cause would be the crank position sensor.
toyo7
03-06-2007 11:45 AM
Liisa
05-01-2006 01:51 PM
tommy7133
02-25-2006 01:35 AM
mrc209
10-04-2005 03:47 AM
tommy7133
08-16-2005 03:02 PM
