'02 SL2 bad engine?
'02 SL2 bad engine?
Just bought my daughter a 2002 SL2, pretty clean inside and out, but it has lifter noise so i took it to the local shop who does a lot of Saturn work. Dealer is pretty far and I didn't want to chance it since the tags are out of date. The car has been sitting for a year, hesitates on acceleration, I figured that was the fuel filter from sitting so long. I had the shop change the oil, the belt, all fluids and reset the check engine light. He said 3 codes came up. knock sensor, o2 sensor and cam sensor. He played with it for a long time and has decided the engine is bad as the oil pressure is too low and wants $1000 for an engine plus $500 install. I already spent $500 with him. I am not sure he is fully accurate, the car starts right up, idles fine, takes right off when you give it gas, if not for the lifter noise and the hesitation I would say it runs great. I need some help from the experts.
He did not say, he did take off the valve cover and visually inspect. He saw oil coming up but not enough to get to the lifters. The lifters are really noisy, all of them. I thought maybe since it was sitting so long they were all stuck, but he changed the oil twice and put in marvel oil to try and quiet them, but no difference.
Things get gunked after 365 days of not flowing........
1) low oil pressure would likely trigger an oil light on the dash and cause more damage throughout
2)there is no cam sensor on an s car--this code sets for other reasons well tackle later
3)don't throw money at the knock sensor just yet.....may be tied to the cam sensor code....
4) sluggishness on accel is likely the front o2 sensor (assuming code was for the front) -- replace with the denso, not the bosch
clear codes, go through a few drive cycles and report back on any remaining codes
You also didn't mention new plugs and wires -- recommended (nothing exotic)
Dealer is by far the best place to buy parts for any and all S-series and L-series SATURNS. I have not, do not, and will never recomend buying Saturn parts from CheckerQuestNapaZone. Just look at the fuel filter you bought for example.
