'02 SL2 bad engine?
Old 11-21-2010 | 11:18 AM
<The car has been sitting for a year, hesitates on acceleration, I figured...>
<It is not sluggish on accel at all, it starts out great, then it gets hessitant,>
hey I can only help as much as you provide accurate info. Which is it?
___________
<<cam senor was a guess on my part because I did not remeber the 3rd code, it was something like that>>
Guessing at codes doesn't help either.
________
Also didn't indicate plugs changed in first post or I wouldn't bother recommending it.
Please provide ALL information up front if you want to receive correct feedback. I'm quite willing to help but without ALL the information, the chances are greatly decreased that we get to the bottom of the problem.
Still recommend changing the 02 sensor and clearing the codes, driving, seeing if bogging improves and if light comes back on.
(the real question being is the engine really knocking bad enough that the knock sensor intervention can't have the pcm adjust the timing or is the knock sensor itself bad)
JAFO1
Engine & Internal
07-09-2008 09:19 PM
94sl2!
04-28-2008 12:25 AM
tsmith1947
01-26-2008 01:44 PM
ben77aries
09-27-2007 09:39 AM
08-05-2007 08:04 AM
