'02 sl2 knock
Old 05-14-2010 | 07:21 PM
sl2mania's Avatar
Default '02 sl2 knock
got serious noise at idle, rev it up, it goes away, some times, the stethiscope gives loud noise at #4 cyl head, less up front, very noisy from the oil; pan, no metal in oil, havent removed the filter yet, had the v-cover off running, no valves looked stuck, no lash adjusters looked loose, running, just very loud knocking that changes w/rpm joe
Old 05-14-2010 | 09:53 PM
guess crank bearing--gotta look
Old 05-14-2010 | 10:20 PM
sl2mania's Avatar
Default brg
after i check oil pressure tomorrow, ill pull the oil filter to investigate, no metal in the oil at all, a bad bearing would contaminate the whole pan, right?
Old 05-15-2010 | 08:38 AM
or rod knock
not a knock expert -- seems to me if it is in the bottom end, you'll need to drop the pan to investigate.
Did the oil get too low?
Old 05-15-2010 | 11:05 PM
?? possibly a wrist pin issue ??
Old 05-16-2010 | 09:42 AM
sl2mania's Avatar
well, i pulled the oil sender, started it up, and it jumped passed 30 psi, with a mechanical gauge, i can rule out lash adjuster pressure, car did not run out of oil, is there a wrist pin/piston issue with these motors? i cant imagine the crank or rod bearings being suspect, the revving up to the point where it quits knocking is making it hard to isolate, im going to split the oil filter next, check for metal, none visible on the stick, if anything let go, it would present contamination, ill post after i dissect.
Old 05-16-2010 | 06:06 PM
?? Wrist pin issue with the engine (as a class problem) ?? Normally, no - not that I'm aware of
equipguy
05-16-2010 06:30 PM
paulsl2
Engine & Internal
11-15-2009 06:24 PM
jllacourse
08-21-2009 04:54 PM
joshhamann2008
10-07-2008 04:27 PM
phreak3739
12-03-2005 02:44 AM
