03 l200 headlight issues
My 03 l200 lights pause and flash when I switch from bright to dim or visa versa and also the security light comes on and stays for a couple seconds then goes back off. Can anyone help me understand this. Im pretty good with mechanic issues but this has me stumped
Need help please
I'm neither an electrician nor a mechanic, but it sounds like a faulty ground or loose connection in the headlight switch to me. Hang around because Andy is our resident L series guru and I'm sure he'll see this and try to help you. Be patient.
Okay, Kracker13. You heard that I thought it might be the headlight switch and our resident L Series guru (and a REAL mechanic) gave you a link as to where to get one,so it appears that Andy agrees with me. That's a cheap and easy fix. Come back and let us know what you decide.
