1997 Saturn SL2 Help
Hot start problem
If the starter turns the engine over easily but the engine won't start (especially after the engine is already warm), it is probably the coolant temp. sensor. That model came with some type of composite sensor which usually develops cracks. The newer sensors are all brass.
