1997 Sl2 help...
Old 01-29-2008 | 11:40 PM
Schmidty's Avatar
I have a 1997 saturn sl2...im 18...so I like loud music naturally...i was wondering if anyone on here knows how to take off that plastic piece in the back...the piece that goes across the trunk and looks like a light...that is the only thing i havent been able to keep from rattling...i just need to knwo if you can take it off...or not...i need to dynamat behind it to get rid of the rattles...and help would be appreciated...thanks...
Edited by: sw2cam
Old 01-30-2008 | 12:38 PM
Low Saturn's Avatar
Its held in place with 10mm nuts. Open the trunk and you can access them from the back side.
I wouldnt recommend using dynomat. I disassembles my rear reflector, sprayed the mating surfaces with Roadkill spray on deadener and put it all back together wet.
My trunk sounds solid as a rock.
Old 01-30-2008 | 11:54 PM
Schmidty's Avatar
i tried getting it off today...we found clamps on the underside...we couldnt get them off...an d we didnt risk breaking it...we didnt see any bolts or nuts on the inside of the trunk...unless theyre way up somewhere we cant reach...i have a roll of dynamat...i just put it where i want it and roll it in so it sticks...worked perfectly on the top of my trunk...ill see if i can find those bolts..
Edited by: sw2cam
Old 01-31-2008 | 07:03 PM
Low Saturn's Avatar
[img]uploads/LowSaturn/reflexpanel.gif[/img]
Old 02-01-2008 | 11:06 PM
Schmidty's Avatar
that helps...thanks for the visual...ill take a look tomorrow...
Edited by: sw2cam
Old 02-03-2008 | 07:22 PM
Low Saturn's Avatar
Did you figure it out?
Old 02-03-2008 | 07:35 PM
Schmidty's Avatar
no...i got those bolts off...but its still clamped on the underside...
ill probably just give up...or else ill break it...
CluelessSL2
04-29-2014 07:44 PM
randolphjones
01-09-2013 03:27 PM
scottys92
Audio/Visual Electronics
08-05-2012 01:32 PM
patocon92
09-13-2009 03:49 PM
satty_kingsb
04-22-2008 07:06 PM
