1997 SW2 Power Steering Brackets
Old 09-14-2006 | 11:15 PM
alunga's Avatar
I just finished replacing the cylinder head on my SW2. I know where to
put everything back EXCEPT for one part-a small black bracket which I
found lying under the car after I had moved the power steering pump
aside. It's not the readily visible one that bolts to top of the intake
manifold, but looks very similar. There is an apparently unused bolt
hole just up from where the timing belt tensioner mounts. Does the
bracket mount to the back side of this, and where exactly does the
other end go? I've spent close to an hour under the car trying to
figure this out.
Old 09-14-2006 | 11:18 PM
alunga's Avatar
I meant to say SERPENTINE belt tensioner, not timing belt.
Old 09-19-2006 | 12:37 AM
onesmartscdt's Avatar
alunga
Send a picture it is worth a million words.there is a bracket under the intake and directly behind the alternator not easy to get to but a distinct possibility.the bracket is offset with tube center and flatened on both sides with a single hole on each end.No longer then 4or 5 inches
Darryl T
JEKoenig0524
02-22-2015 07:43 PM
dbhost
12-06-2011 05:03 PM
saturne20
08-01-2008 11:14 AM
lynn
Saturn L300
09-12-2006 03:10 PM
