1999 SL1 High Pitched Whine
Old 10-06-2005 | 02:02 AM
earthrnangl's Avatar
I have a 1999 SL1 which is making ahigh pitch almost wind up key noise henever I accelerate. Anyone know what could be causing this or better yet how I can fix it. Thanks.
Old 10-06-2005 | 05:44 AM
desperado's Avatar
the last time i encountered a problem of that sort, a new fan belt replacement did the whole trick.
Old 10-06-2005 | 09:03 PM
Thanks. I'll give it a try.
Old 10-17-2005 | 03:48 AM
rick_ryder's Avatar
If the noise goes up and down with enging rpm it's probably the alternator on its way out. If it's not a squeel? when the bearings start to go in the altthey make a good whinnnig sound. There is another bearing on the idler pully, located right below the top mount, that can cause a whine also when it time is almost up.The alt should be putting out about 96 amps under load so if you get it tested at a shop and the say its look ok make sure the amperage is in the high 80 at least. when the bearings start to go the alt usually puts out about 60-70 amp ok for some cars but not for saturns.
helistructor
11-14-2010 08:16 PM
Sage927
11-07-2010 06:03 PM
Larissa72
01-19-2008 08:36 PM
Benjiboy_01
02-13-2007 05:31 PM
blind527
11-22-2006 10:33 PM
