2001 SL2 Power Steering Pump Pulley exploded.
Old 11-26-2011 | 06:12 PM
dbhost's Avatar
Default 2001 SL2 Power Steering Pump Pulley exploded.
The power steering pump on my '01 SL2 literally exploded on the freeway the night before thanksgiving. I have the new one, but can't figure out how the hub comes off the shaft. I know there is a hex bolt in there, but can't seem to get it to break loose even with a cheater pipe... Is this thing right threaded instead of left?
Old 11-26-2011 | 06:29 PM
Look at, and envision which way the pump spins during normal operation ... the hex bolt will spin the same direction to tighten it's lock on the pulley
Old 11-26-2011 | 06:48 PM
dbhost's Avatar
I admit to being a dummy here... Not certain of the direction of rotation here. I think its clockwise... Not sure...
Old 11-26-2011 | 07:16 PM
What way does your engine turn, now what way would the belt turn the pump when it's bolted to the engine?
Old 12-02-2011 | 05:57 PM
dbhost's Avatar
Got the pump pulled... Getting the pulley swapped now.
Old 12-06-2011 | 03:32 PM
dbhost's Avatar
Okay, got it all done by Saturday afternoon. And a couple of items to note...
#1. There is no fastener holding the pulley to the shaft. It is a press fit, and requires a puller / press to swap over.
#2. Paying attention to the manual is a good idea. There isn't enough room under the hood to reattach the power steering lines with the pump in the car, you MUST remove the lines from the steering gear / rack below and then pump from above, then remove / reattach the lines...
#3. Swapping the pulley / pump was the easy part. Getting that *#%# belt back on was a different story all together...
Oh well, at least it is back together, and I am driving it now... Driving my F150 4x4 is a ton of fun, but I HATE feeding it...
Old 12-06-2011 | 05:03 PM
glad you are back on the road -- and thank you for posting the details of your resolution to save someone else down the line some time
dgvscn
11-09-2008 02:36 PM
TWOHED5
08-28-2008 01:08 PM
hkn royalt
07-07-2008 10:08 AM
satty_kingsb
05-08-2008 03:07 PM
mfunk49
02-01-2007 07:24 PM
