2002 L200 Not starting
Old 02-15-2011 | 12:16 AM
MLC1990's Avatar
Default 2002 L200 Not starting
I have a 2002 L200 Saturn. I drove my car around town and to work this morning and didn't have any problems with it what so ever. No service engine lights popped up nothing. My car has a full tank of gas, it had an oil change and was winter inspected last month. The car has about 128,000 miles on it. When I got out of work, my car would not start up. There is no crank, no noise, nothing and the service engine soon light stays on. The lights and radio work perfectly fine. I called AAA and had them try and jump start it but it didn't do anything. Anyone have any ideas on what the problem may be? Any help and advice would be greatly appreciated.
Old 02-15-2011 | 08:56 AM
I know this is kinda simplistic, but check the fuses in the UHJB (fuse block in the engine compartment). Make sure they are all good.
Old 03-06-2011 | 02:16 PM
Sudre's Avatar
Did this get fixed? I was curious if you have a car alarm on it. I had an after factory alarm on my 94 SL2 and someone tried to steal it.... someone who almost knew what they were doing. The alarm cut the engine ignition since it was still armed when they tried to start it.
It chirped three times when I disarmed it (stopped alarming because it was left alone for long enough)
I tried to start it and nothing happened.
Called the installer to learn how to reset it.
Worked fine after reset.
There was a switch under the dash I had to flip while I turned the key.
Just a shot in the dark.
whitelee28
09-18-2010 10:19 PM
Baobab
07-10-2010 10:29 AM
mrnick86
05-01-2008 04:11 PM
groingo
02-18-2008 10:55 PM
saturn28027
03-12-2007 01:41 AM
