2003 Vue AC problem
![Default](/forum/images/icons/icon1.gif)
AC clutch cycles quickly(less than a second) but not often,maybe every 10 seconds.All lines,receiver leading to and from compressor are clear.If I jump out the compressor I climb to a high head (up to 350lb)and high back of 40lb. and the engine will stall.Trying to figure whats wrong and wonder how sytem is controlled?There appears to be a "Pressure Sensor and Pressure Sensor Valve mounted to the compressor on the manifold holding the liquid and suction line.Could this be the problem?I don't know what it controlls!!
Any help appreciated
Jim
134a, 2003, air, common, compressor, conditioner, conditioning, jump, pressure, problems, suction, vue, working
