2004 Ion 2 misfire
Old 04-14-2009 | 09:24 AM
Gateway's Avatar
Question 2004 Ion 2 misfire
Got a prob. here and looking for some help. I was driving my car and everything was fine till i shut it off. I started it back up 5 min. later and it was shaking like crazy and the engine light was flashing. brought it to auto parts store and got the code reading engine misfire. I am figuring this is either ignition controll module or the coil pack. I am leaning toward the ICM. Any thoughts on this from anyone? Both parts are relativly cheap, just seems like a 50/50 shot to me. Any suggestions on which to buy first? Thanx for any help.
Old 04-14-2009 | 11:27 PM
Neither.
Check plug wires and plugs first.
If the engine code was a misfire specific to a cylinder, most of your homework is done.....
Old 04-15-2009 | 11:04 PM
Gateway's Avatar
Talking Problem Solved
I changed the spark plugs and boots but this did not fix my problem. So with my 50/50 chance i bought the ICM for $76.00 and got lucky. Engine code is gone and car is back to smooth operation
Old 04-15-2009 | 11:47 PM
Plug wires ............... what plug wires
Old 04-16-2009 | 06:58 AM
clearly I've never been under the hood of an ion -- I had assumed they haven't done away with such simple things...please send me an Ion manual so I can answer the ion questions right.
Derf: 2 demerits.
Glad to hear you are up and running -- my apologies for the misguided guidance.
Old 04-16-2009 | 09:18 AM
Gateway's Avatar
Default No wires
I don't know about other Saturn models, but the 04' Ion doesn't actually have spark plug wires. The Coil pack which is one unit with the ICM screwed on top of it sits above the spark plugs on the center of the engine. Instead of actual wires there r boots that connect from the coil towers down on top of the plugs. no wires, just boots.
Old 04-16-2009 | 09:19 AM
Gateway's Avatar
no prob with any misguided guidance. A tune up never hurt any car as far as i know. Thanx for the help
kvss.ravi
03-30-2012 07:49 PM
wapayne
09-06-2011 05:08 PM
calgone74
07-11-2011 07:37 PM
silverion3
01-17-2011 08:15 AM
