93 SL1 starter keeps blowing
Old 01-16-2009 | 07:58 AM
Sounds like the old Ford starters ... had to put a shim (spacer) under one side of the mounting surface of the starter to keep it aligned with the face of the flywheel. Where are you buying these starters? Are they dealership bought, or are they after-market replacements ??
Old 01-16-2009 | 10:20 AM
turbozeke418's Avatar
Aftermarket replacements from Pep Boys.
Old 01-16-2009 | 11:02 AM
Uh, huh ... Pep Boys ... Larry, Curly and Moe (lol)
I was raised in California, so I am real familiar with their products. You have my sympathy.
Old 01-19-2009 | 02:14 PM
Green98SL2's Avatar
The wire with the black connector on it that you are pointing to goes to the Anti-Knock Sensor which is screwed into the block. It is round and has a black connector on top of it in the middle that the wire Snaps onto (The connector on yours looks a little different than this one). Hope this info helps.
Old 01-19-2009 | 03:21 PM
Ok thanks. Only problem is I don''t see this anywhere near where this wire is hanging. Is there an exact location. I guess its possible that the top of this broke off which is why the other piece is hanging around.
Old 01-26-2009 | 07:23 PM
i replaced the + cable and the car starts perfectly now. Thanks for all the help. I still can''t figure out where the anti-knock sensor is and where that wire goes, but i can live with the check engine light on.
Old 01-26-2009 | 09:57 PM
It is simply amazing what a corroded battery cable will do ...
561saturn
05-26-2013 01:30 AM
pmk
06-22-2009 10:21 PM
racer76
07-07-2008 09:05 AM
Rincon
05-08-2008 11:31 AM
tennisknight
11-29-2006 12:23 AM
Quick Reply: 93 SL1 starter keeps blowing
