Brake Problem
Brake Problem
I have a 1998 SL2. The brakes work fine until I after I drive like 15 miles then the brake pedal gets hard and the brakes start to lock up on me. I have checked the fluid and that is fine. The hoses to the calipers also seem to be fine. I put new calipers, rotors and pads in the front hoping that would solve the problem but no luck. What should I check next?
Hopefully, the re-bleeding of the system will take care of your problem. While you are under there, check for any suspicious indications of leaks or drips from the brake line fittings - they need to be tight
