changing gear oil 98sl
Old 11-16-2009 | 05:29 PM
turbochargedv8's Avatar
Default changing gear oil 98sl
might be able to get my 98sl to school and use the lift would this be straight forward changing the gear oil or is the drains in an odd place any write up or tips so i don't look more tarded than i already am
Old 11-17-2009 | 12:31 AM
saturnsdn's Avatar
its pretty straight forward. drain on bottom fill from top where dip stick is. the trans uses atf regardless if manual or auto
Old 12-09-2009 | 09:08 AM
roberank's Avatar
I encounter the same problem as you sir.
And now i ask my brother to fix it.
any advice to make it more faster but
can assure the safety?
s10blazer99
02-26-2011 04:35 PM
turbochargedv8
12-26-2009 12:17 PM
turbochargedv8
11-15-2009 08:18 AM
ASKBCG
10-20-2007 09:34 PM
X-Vert
03-03-2007 10:48 PM
