Engine Coolant Light and Gauge NEED HELP PLEASE!!!
Old 05-18-2011 | 10:31 AM
jeffandsonia's Avatar
Default Engine Coolant Light and Gauge NEED HELP PLEASE!!!
A month ago the engine temperature light started flashing really fast and often along with the engine temp gauge just flickering back and forth for no reason. So had the coolant flushed thinking that was it. No Luck, so had the Engine Coolant Temperature Sensor Changed still no Luck, then was told by Midas that the Thermostat was sticking and that was it so had that done and still no luck. Car runs fine but the engine coolant/temp light and engine temp gauge keeps coming up and flickering. No bells or sounds just flashes. Car is 2003 L200 with 52000 miles. Any help is greatly appreicated as what else could be causing this!!!!
PLEASE HELP!!!!
Old 05-18-2011 | 10:45 AM
Default Is there two ECTS'S??????
Are there two ECTS's? I believe the one they replaced was under the reserve tank. I thought the ECTS was on the engine block.
Thanks
Old 05-18-2011 | 11:41 AM
Sounds like they replaced the coolant reservoir switch.
The Engine Coolant Temperature Sensor (ECTS) is located at the lower left corner of the cylinder head, on the thermostat housing
Old 05-18-2011 | 05:21 PM
Thanks, OceanArcher, after looking at the engine again just now they did replace the ECTS. However could there still be an issue with the connection on the ECTS that they over looked? If so what should I look for? Also could the coolant reservoir switch cause this problem?
Thanks
Old 05-18-2011 | 06:32 PM
Yes there could be ... If I replace an ECTS, I also replace the connector that attaches to it. Costs an extra $25usd or so (GM part), but it gets rid of annoying intermittant connections.
Coolant reservoir switch (the boat) can get gummed up if the wrong coolant is/was used. Most times, simply removing the tank and flushing it with vigorous shaking will free it up, but sometimes you gotta bite the bullet and replace it.
Old 05-19-2011 | 09:14 AM
Default ECTS Connector
OceanArcher, thanks again! Where can I buy the connector? I have looked online and have had no luck locating it anywhere.
THANKS!!!!!
Old 05-19-2011 | 09:19 AM
Usually you can get that connector at a GM dealership. Check locally and see who took over the Saturn dealership nearest you, they often absorbed the remaining parts inventory and technical staff. For me, it's a Cadillac dealership in Mobile, off I-65 ...
spinrb8
02-17-2013 11:24 PM
genetic
05-30-2009 07:30 PM
bills
02-15-2009 04:01 PM
rabobanks
07-07-2008 10:10 AM
dendaden
Engine & Internal
10-22-2007 06:46 PM
