gas mileage
The S-cars were first produced in 1991.
The SL1 for 2001 was rated by the factory at 27 town, 37 highway. Personally, I have found that these numbers are a bit more than the "average" driver will attain. 24 in town, and 34 on the road will be a good expectation ....
I really do appreciate your quick answers, I can believe a 97 would get better mpg than a 2001 because of all the sensors they have on this car. So far I have changed the TPS throttle position sensor (engine was idling to fast). Then the AIC air idle control, car is still slow on idling down. Then I changed the CPS crankshaft position sensor because it was bad according to the diagnostic readout. But the engine is still slow to get down to the correct idle speed. Ive had the throttle body off twice and there is no binding or poor spring tension. The knock sensor is going to be my next fix, I guess.
Ocean Archer, For decades Amercian car companies would inflate their mileage claims. I was told that they did their testing on windless days, on perfectly flat roads, with the slightest acceleration to make these mpg numbers. I do believe that your 24/34 mpg are about right, Thanks again
After reading my own posting stating that American car companies stretched the truth some on the mpg, I realize some may think I'm pro Japanese imports which is not the case, I have never owned or ever will buy Any Japanese cars made here or imported. In my opinion GM dropped the ball along time ago. They thought they were to big to topple to the imports. I really lost my passion for GM for years now but I will not buy a Japanese car.
fm220 .... car companies do not make mileage claims. The stickers on the windows are required by the goverment and the government comes up with the numbers.
read, understand, learn, understand
www.fueleconomy.gov
www.fueleconomy.gov
If it's true about the gov't coming up with numbers that's fraud on a large scale. I was in the Air Force and I know that a lot of serious things happen and the gov't does not let the information get put on TV or newspapers. But this is pretty weird if they tell the car companies what to put on the new cars at the dealership.
Most everything on the label is required by the government. When a car company says a car gets a number of mpg it's gets the number from the government. Where is the fraud, the car company reports what the goverment tell them to report. Nothing weird about it, it's just the way it works, and has nothing to do with the military.
