hard to remove fuel cap
Old 03-20-2011 | 11:14 PM
airjet's Avatar
Default hard to remove fuel cap
I have a 2004 Saturn Vue, 6 cyl. The fuel cap is now very difficult to remove. I do not have any engine light to come on to indicate a problem that would be related to a loose fuel cap. When I try to remove the cap, it just clicks as I turn it. When I do remove it, and then put it back on, I can turn it all I want and it clicks, but never fastens tight. I can't even remember now if it's supposed to fasten tight. It seems that it is taking me longer now to remove it, I feel almost like I am cracking a safe.
Does anyone have a suggestion to help me get it off quicker? Thanks for any advice.
Old 03-20-2011 | 11:22 PM
stop futzing with it and go to the dealer and buy a replacement
Old 03-20-2011 | 11:58 PM
Seems like the thing to do to me ......... after-all it is just a gascap.
Old 03-21-2011 | 12:03 AM
You have to be kidding ................... you can not figure out all by yourself you need to replace the fuelcap.
Old 03-21-2011 | 08:59 AM
Believe it or not, but the gas cap can fail. OEM replacements are available at nearly every GM dealership (not very expensive, either)
Old 03-21-2011 | 08:16 PM
airjet's Avatar
Ok, fellers. I appreciate your replies and I will buy a fuel cap from the dealer when I can. I sure wish I understood how these things work tho. Thanks again.
KZinOKC
08-22-2015 12:29 AM
jamnar
07-25-2015 11:56 PM
davidray
03-18-2011 07:38 PM
Icurl4
09-30-2008 10:19 AM
mikes 1994 z28
06-12-2006 05:19 PM
