Headlight question
Headlight question
I have a 1995 SC2 and when ever I close the electric headlights there is a loud grinding sound from the passenger headlight assembly for about 5 seconds after the headlight closes. Can someone tell me what causes this and how I can fix it? Thanks for any help.
USE AT YOUR OWN RISK
To the inside edge of each headlight is a manual raise-lower **** (covered by a rubber boot which just pulls off). You will likely notice that the two headlights are at different "positions" with regards to how many turns of the **** it takes to hit the limit.
KEEP TRACK OF THE NUMBER OF TURNS ON GOOD ONE SO YOU CAN PUT IT BACK PROPERLY.
Adjust the offending headlight to match the properly functioning one.
Have had to do this twice during the life of my 95SC2.
Quite empirical but works for me
