injector problems
Old 04-24-2010 | 02:51 PM
evan's Avatar
Unhappy injector problems
This is a 91 sl1 with a 1.9 dohc. With all injectors pluged in the car will start and die. with the connector for injector 2 disconnected the car will start and run on the other 3 cylinders. as soon as you plug it back in the car will die. I am wondering if this is a pcm problem or something similiar. Also both wires on the injector connector have batt voltage. Have checked for codes the only thing is code 26 for quad driver. Any info would be very helpful. thank you.
Old 04-24-2010 | 06:09 PM
If it has a DOHC, it's an SL2....
With the engine off, pull the injector connectors and measure the resistance of each injector and report back.
One thing that came to mind (though we need to do some more troubleshooting) is that the injector my be stuck open when connected and dumping so much fuel that the rest of the cyls are not getting sufficient fuel for the engine to run.
I will brush up on fuel injection system behavior for the earlier cars -- they had different types of injectors than the later years
As for Code 26
quad driver fault codes are almost never from actual quad driver failure
from one of my earlier posts-----
code 26 (quad driver output fault) is almost never the actual quad driver within the PCM itself; it is almost always something hanging off that circuit. This circuit is used to simultaneously monitor the status of
SES circuit
Coolant Hot light
cooling fan relay
A/C clutch
Speedometer Cutout
Upshift/Shift to D2 light
EGR solenoid
Canister purge solenoid
Diag in the order listed.
pauledgar
10-23-2012 08:05 AM
saturnspeed99
12-27-2011 12:44 AM
coledigger4
10-24-2009 01:48 PM
sylance
09-22-2009 09:30 PM
datlas
06-11-2007 10:59 PM
