instrument panel lights
Old 01-03-2011 | 12:57 PM
john doe's Avatar
Default instrument panel lights
only half my speedo lights up .must be a bulb out .
can you get to the bulbs on a 2002 sc2 just by removing the top dash pad?
Old 01-03-2011 | 09:49 PM
Dunno!
Old 01-03-2011 | 10:22 PM
i'll up your dunno to a "pretty sure". Removing top allows access to the inst panel.
Be sure to replace them all while you're in there as the jostling of the older ones that still work will likely hasten their death and you don't wanna have to do the job twice
Old 01-04-2011 | 02:08 AM
john doe's Avatar
i seen a video on utube that looked like you could just by removing the dashpad. but in the video he was removing the entire cluster.
both sides of the speedo should light up brightly i assume??like the tach does
Old 01-04-2011 | 04:24 PM
Yes -- both sides of the speedo should light up
saturns_moon
01-24-2014 12:20 PM
Rubehayseed
07-31-2011 12:29 PM
anndruu12
02-05-2011 05:00 PM
snapprhead
01-25-2008 08:38 PM
AwolRJ
03-04-2007 02:31 PM
