Interment turn signals
Actually, the flasher unit itself controls all of the lights through a single set of contacts. If it works OK when you switch the hazard lights on, it is not the culprit.
I suspect that the switch on the steering column is probably to blame; either that, or loose/defective wiring in the circuit from the steering column to the flasher unit (which is located on the instrument panel fuse block).
