New car, few problems
Old 02-12-2012 | 09:54 PM
Abe'sGST's Avatar
Default New car, few problems
Hey guys, i just bought a 2002 SC-1, really great shape but with a few problems. The main problem I figured out is that it needs a new intake gasket, it idles high and has a misfire on just #1 cylinder. I will start working on that tomorrow. 2nd problem I noticed is that that when I pop the trunk there is a small little area with water on the left side. I read somewhere that these cars tend to have both these two problems. Is there anything i should look out for while replacing the intake gasket? Anything i should replace in the trunk?
Thanks and sorry for the long post
Abe
Old 02-13-2012 | 10:49 AM
SC1 SOHC ............ Could very well be an intake leak. Matter of a fact sounds to me that you do have an intake leak. Common problem with the SOHC.
Old 02-13-2012 | 11:05 AM
Check the rubber seal along the top of the trunk lid. It can get pushed loose from loading/unloading, and get cut when the lid is closed again....
Old 02-13-2012 | 11:54 AM
Abe'sGST's Avatar
Ok, ill check that, thanks. Anything I should look out for while replacing the intake gasket?
Old 02-13-2012 | 12:07 PM
Nothing really to look out for. Do a leak test before you start rippings things apart. You don't want to do the work for nothing.
http://answers.yahoo.com/question/in...5032711AA8JWgy
arod812
11-18-2012 05:20 AM
countryrocker18
08-16-2011 10:05 AM
one54ton
04-24-2010 03:31 PM
iturnbolts
09-21-2008 01:05 PM
bannock
09-22-2007 11:54 PM
