Off idle "stumble", ’’01 SC2
Old 01-19-2009 | 09:01 AM
superspeeder's Avatar
Stable needle does not guarantee correct temp reading from sensor. Original resin tipped design are known to crack and provide bogus temp readings to PCMusually that coolant temp is too cold. This causes engine to run rich and will create the type of behavior you are experiencing.
As for connector, yes, corrosion here is a killer and will hose the reading from a brand new sensor.
This is 100% correct in my case, except my original (failed) ECT sensor was the brass-tipped version! Put a new one in (looked the same as the one that came out) and all is well now. The needle on the coolant temp gauge was smooth, it just never got to the right temperature, likely causing the rich condition you described. Good diagnosis doc!
EDIT: I didn''t replace the connector, it was clean and corrosion free inside and seems to work fine. The dealer wanted TWICE the ECT sensor price just for the connector!Edited by: superspeeder
Old 01-19-2009 | 11:27 AM
SuperSpeeder ...
You are right, the new connector is double the cost of the sensor. I guess they are proud of their part, but you have to pay the piper ... I have never found the connector in the after market
Quadcouper
02-02-2014 05:13 PM
DavidBunin
07-21-2007 06:36 PM
torqueaddict
01-07-2006 10:48 AM
torqueaddict
01-01-2006 12:12 AM
2seater
12-16-2005 11:53 PM
