Over heating SL2
Old 09-19-2011 | 08:41 AM
Probably a couple of stupid questions, but I'm going to state the obvious anyway. Have you checked the thermostat and are your running a 50/50 blend of anti-freeze and distilled water?
Old 09-19-2011 | 03:36 PM
Chainsaw's Avatar
Ok I replaced the cap with two wires on it and the temp heat sensor that it attaches to all with GM factory parts but I still have the same problem. Car starts out fine, nice and cold but as it heats up fan does not kick in. The heat gauge says just over the half way point and then the boiling over and steam starts.
Any more suggestions would be appreciated.
Thanks,
Old 09-19-2011 | 03:39 PM
Chainsaw's Avatar
I haven't pulled the thermostat yet but will. I was running 50/50 however it has boiled over so many times that it is probably closer to 90 water/10 antifreeze right now.
Old 09-19-2011 | 04:07 PM
So from cold start up how long did it take to start boiling water out this time?
Old 09-19-2011 | 05:43 PM
Chainsaw's Avatar
15 to 18 minutes at idle from cold start, air temp about 80 degrees. hood was open which might make a small difference vs a closed hood for trapping heat.
Old 09-19-2011 | 06:54 PM
Chainsaw's Avatar
More info which may or maynot help. I just ran it for 30 minutes at idle with AC on so fan was running. Did not overheat and heat gauge did not get to half way mark. So the problem is not the water pump but just the fan coming on at the proper time.
rjs
12-13-2013 11:30 PM
5.9cummins
07-14-2013 01:56 PM
Vanderworkenm
06-26-2013 02:59 PM
rosiegirl1
08-08-2010 05:38 PM
SL2 pirate
05-09-2008 10:33 AM
