P0733 Valve Body
Old 01-10-2009 | 08:50 PM
2001 saturn sl2's Avatar
I have a 2001 SL2. I had some transmission problems recently and had the valve body replaced. This seemed to fix the problem for a few weeks but now the problems are back (not as severe) and the check engine light is on. (P0733 code). Transmissionslams occasionally and sometimesruns as if there is excessive backpressure and the engine struggles to go.
Mechanic said I''d need to take the car to the dealer to flash the computer.
I read about replacing the throttle position sensor to fix the code issue.
Anyone have a similar issue?
Old 01-10-2009 | 10:53 PM
P0733 is still blaming the transmission.
Hopefully, the shop that did your transmission work gave you a warranty, cuz the computer is telling youthe transmission isstill messed up.
The transmission slam and the engine struggle seem to bear that out
Old 01-10-2009 | 11:09 PM
Ya what ever you do don''''t take it to the dealer because they know what they are doing. Take it to Joes Crab Shack and Transmission repair.
So your in North Royalton or are you in FloridaEdited by: sw2cam
02saturnsl1
11-08-2013 11:22 PM
saturntech
10-11-2007 12:10 PM
hartman
04-09-2007 01:13 PM
2DOLLAR
04-26-2006 05:44 PM
bign90
10-17-2005 06:48 PM
