PCM 93 SC2
Old 02-19-2006 | 08:58 PM
rugerb's Avatar
I have a 93 SC2 with 100,00 miles. It use to run great, then engine light on and bad gas mileage. Spent $700 to mechanic who changed a # of things, EGR, EGR relay, temp sendors, etc........brought it to another mechanic who put it back on computer which the codes indicate the cars PCM is not working properly, sending wrong signals to car. Got another PCM from junkyard, plugged it in, car runs but not properly, doesn't shift right. Guy told me to reprogram touch negative to positive battery terminal(while still connected) to reprogram computer. Didn't really work. any suggestions would be greatly appreciated...Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![img]smileys/smiley19.gif[/img]
Old 02-21-2006 | 05:44 PM
ottjoe88's Avatar
after replacing the computer it may take a bit to reset and it will shift hard for a little bt
Old 02-25-2006 | 09:56 AM
stevestar99's Avatar
Ottjoe is right the PCM should reprogram after couple of open road drives.I hope theguy that told you to short the battery terminals together, told you to disconnect the battery first. When you disconnect the battery, the PCM will lose it memory ina couple of minutes. With the battery disconnected, touching the terminals together just speeds up the process. If you want to reset your PCM without disconnecting the battery, pull the "PCM B" fuse (powertrain control module memory)for a couple of minutes.
cathryncay
07-13-2009 09:14 PM
saturnfan1
07-07-2008 10:07 AM
JOE110461
02-11-2008 08:44 PM
ray3483
05-09-2006 01:39 PM
rugerb
04-23-2006 03:17 PM
