power door lock issue
Old 08-22-2008 | 10:46 PM
mflury's Avatar
I have an 2002 SC2. Recently the power door lock button quick functioning. I hear a click under the pass dash when depressed but no locking on either side. As a note unlock function still works. Any ideas where to start the troubleshooting? Well actually my Hanes manual may have something but I''''ve already posted so I guess I''ll approach from two directions.
Help is always appreciated greatly.Edited by: mflury
Old 08-24-2008 | 12:08 AM
Low Saturn's Avatar
You you enter the car with the key or using the key fob? Make sure both lock cyinders are in the vertical position.
Also try swapping the lock and unlock relays and see if the problem follows.Edited by: Low Saturn
Old 08-24-2008 | 03:47 PM
mflury's Avatar
I use the key. I don''t have a remote so I can''t try that.But I will track down the relay and see what I can do.
Thank you Low.
wes0778
06-18-2011 07:29 PM
tealsc1
05-17-2010 05:04 PM
alex_0227
07-18-2009 08:36 AM
troythefixer
10-26-2008 04:45 PM
NBR_JasonB
06-18-2006 03:00 PM
