Removed stereo, now car won't start
Old 06-04-2009 | 10:07 AM
naener80's Avatar
Default Removed stereo, now car won't start
I removed the stereo in my 02 Saturn SC1 in order to get a CD that was stuck in the player. In order to get the stereo out, I had to remove the dash panel that goes across the steering column, gages and down the front of the ac/stereo. After I reinstalled the stereo & panel my car won’t start. It will crank once or twice… then nothing. It is not clicking as if the battery is dead, but if I jump it with cables it starts. I am wondering if when removed the dash I inadvertently pulled something lose.
In addition, I have been having problems with turning my key in the ignition. I wiggle the wheel for a while and jiggle the key it will finally turn
Old 06-04-2009 | 01:46 PM
Replace the ignition switch module before it fails entirely, when you are parked on a dark road somewhere, all alone, and a dead cell phone .......
Old 06-11-2009 | 06:02 PM
denverboardguy's Avatar
my first thought in reading this was a security system issue. My friend had a similiar problem on his chevy malibu after messing with the stereo but you can jump it so i dont know
re: ignition assembly, yeah replace that quicklike. In my experience that is NOTORIOUS to go out in every saturn i've owned. My last one went through three...
Old 06-11-2009 | 07:56 PM
If you took all of that out of the car to remove the radio then your an idiot.
Old 06-12-2009 | 01:34 AM
woefully uninformed at a minimum
tikidude
08-30-2014 06:04 PM
04-24-2013 09:49 AM
adonax
03-29-2013 10:28 PM
Barnaum
06-04-2011 09:26 AM
