SC2 P0733 Incorrect 3rd Gear Ratio
Old 08-23-2005 | 10:33 AM
bign90's Avatar
Hi,
I have a 97 sc2 that I get codes P0733 Incorrect 3rd Gear Ratio and
P0734 Incorrect 4th Gear Ratio
Any idea what would cause this and how to fix it?
Thanks,
Mark
Old 10-17-2005 | 04:34 AM
rick_ryder's Avatar
Incorrect ratio usually means slippin trans. Is the fluid full? what does the car drive like? does the check enginelight come back on as soon as you clear it or does it take a while?
Old 10-17-2005 | 04:28 PM
Patrick's Avatar
Administrator
also,I believe that those have a trans control unit? or a shift solenoid? if the car seems to drive and run fine, i woudl think that it is an electrical issue.
Old 10-17-2005 | 06:48 PM
ottjoe88's Avatar
control module in the transmission needs to be replaced, it is fairley easy to do
AConsciousEarth
04-30-2013 10:20 AM
Devefaux
Engine & Internal
03-16-2009 08:11 PM
2001 saturn sl2
01-10-2009 11:09 PM
MHenry
03-26-2007 02:39 PM
boogawooga
05-24-2006 11:17 AM
