sl2 having a hard time starting
Old 07-18-2008 | 09:57 PM
cobra248's Avatar
I took a beat up 97 sl2 as part of the deal when I sold my car. I
replaced the radiator, thermostat, plugs/wires, fuel/oil/air filter,
egr valve, map/o2 sensor, and a few other small things as soon as I got
the car. It drove fine but then developed a problem where the fuel
pressure would build and fall as soon as the pump shut off. I replaced
the fuel pump and drove it down the road and it stalled. It took me
like 5 min to get it started. Now after I get it to start the motor
will idle fine, but when I give it gas the motor bogs down before it
revs up. The fuel pressure and spark is good. Any ideas?
Old 07-19-2008 | 06:41 AM
Have you replaced the ECTS and its connector?
Search ECTS on the forum........
Derf
Old 07-19-2008 | 10:40 AM
cobra248's Avatar
well... I am pretty sure that part has gone bad, I just didn''t know that the temp sensor would cause that big of a problem. I am going to replace it and see if it works.
Old 07-19-2008 | 12:53 PM
cobra248's Avatar
Ok... I replaced the ECTS and that solved the problem, Thanks for the help.
French Chocolate
10-20-2012 10:36 AM
cremevette
05-16-2011 06:41 PM
SSim
03-03-2011 10:42 PM
ion87-87
02-12-2009 10:40 PM
bruce2003
09-10-2008 07:35 AM
