started the car, key fell out
Old 07-21-2011 | 12:07 PM
4x4Jeep's Avatar
Default started the car, key fell out
today when i turned the ignition on the key fell out and was still running. is this normal? i just put it back in turned it off and started it again, and was able to move the key back and forth. i've never seen that happen before. is it a problem?
Old 07-21-2011 | 03:18 PM
scotterichmond's Avatar
Well it won't hurt anything unless the switch can be turned by another key, or blade or whatever. What is really wrong is the lock mechanism is worn out. I would life with it, but I am cheap/tight/a Scottsman.
Old 07-21-2011 | 06:12 PM
hoseppi's Avatar
That is a fairly common problem with S series cars. It should still lock in the lock position after you remove the key. It is caused by the combination of a worn key, and a worn cylinder. Getting a new key cut from the VIN (as opposed to duplicating the worn key) might cure the problem temporarily.
Old 07-21-2011 | 11:09 PM
4x4Jeep's Avatar
it's no big deal to me, just thought it was strange.
Old 08-13-2011 | 02:57 PM
gunner84's Avatar
my '02 sc2 does the same thing.. I got freaked out due to my key was on a landard and i moved my leg and the key came out.. I got a copy of that key made and shockingly it didn't come out...
**Question** does you key fight you/hard for it to turn into start?
Old 08-15-2011 | 11:55 PM
Originally Posted by hoseppi
Getting a new key cut from the VIN....
Old 09-13-2011 | 04:55 PM
R1pperZ's Avatar
My '95 SC2 did this as well. Didn't think much of it until I went to turn the engine off one day and the key turned just passed the ACC position and stopped. Guess the whole ignition lock cylinder ceased as it was so worn out. Luckily it decided to happen as I was stopping to buy oil at my local auto parts store and they carried my models lock cylinder.
Old 09-14-2011 | 12:23 AM
Well at least the engine didn't fall out, so things are looking up.
04-24-2013 09:49 AM
Dizzy
15
05-31-2012 02:58 PM
chanley939
03-09-2012 07:14 PM
jackers3
07-26-2009 11:53 AM
