Suspension knocking noise
Hi all-
I have a 1998 SW2 73K and have been trying to quite the front suspension for a month. The car makes a bump/knock noise when the suspension is at the top of it's stroke. It lightly rattles when you go over bumps. The shop replaced both upper strut mount/bushings. Noise got worse.The shop replaced one of the struts. Noise went away for a weekthencame back. I noticed,when the car is bounced with the hood up, you can feel a knock at the top of the right strut tower. Should I have the other strut replaced. The shop said it wasnt leaking. Help!
Ken
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
S cars is bad for having the lower control arms bolt being loose. Check and see if those nuts and bolt are tight.
