Tach Signal Wire?
White wire at ignition module or at the instrument cluster electrical connector.
http://www.differentracing.com/tech_...onnectorfaces/ 91-94ipcluster.html
OK thanks for the info i will take a look later and see if i can find that. Someone else was telling me that it could also be the white wire going to the coil packs, not sure if this is right also.
Edited by: 1994sw1
The coil packs sit on top the the ignition module. The electrical connector actually plugs into the ignition module, not the coil packs. The only thing "connected" to the coil packs are the spark plug wires. Edited by: Low Saturn
