timing help
Ok, you mean the cam timing.I thought you meant ignition timing to diminish a spark knock or other engine noises. If you are reinstalling the original chain, gears,guides and tensioner, the Haynes manual provides adequate instruction. If it is a new set,it should come with manufacturer specific instructions, or check the Richpin series on You Tube. I just checked and there is no Richpin video on timing chain installation
