water leak into front floor
Old 08-01-2007 | 04:53 PM
hogman's Avatar
2002 L200.. water gets into the front pass. floor both sides,
Not rain. Radiator level OK.. floor is soaked!!!Cowl drains are open.Could be A/C draining
into car?? How/where??
HELP!!!
Old 08-01-2007 | 08:25 PM
ducky's Avatar
If you have good a/c then the condensation water from the a/c isn't leaving the drain valve b/c its clogged and running out the cracks and crevices of the HVAC box. On the firewall near the middle at the bottom is a small rubber duck valve that opens to let condensation out but prevent nature from finding a home in your HVAC box. Sediment from the outside eventually gets in there to clog the drain. When you find the drain just poke it open with a pencil tip or similar and watch the water rush out.
Old 08-02-2007 | 11:25 AM
hogman's Avatar
Thanks!!!!! This is actually my daughters car she is in TX
and I am in AZ, so it may take a day or three for her to get this
done.. will let you konw what happens.. Very annoying problem!!!
Dealer said they would be glad to look into it for like $80/hr.!!!!
Old 08-02-2007 | 12:09 PM
hogman's Avatar
Can one clean the drain hose from the top, or must you
go underneath car??
thanks...
Old 08-02-2007 | 07:54 PM
ducky's Avatar
The drain hose is internal to the HVAC box; access is by tearing apart the dash so the front firewall is the only way.
cmgrav
11-29-2015 04:48 PM
frostyman
04-17-2011 03:18 PM
wobby
12-16-2008 05:44 PM
tandaroy
03-29-2008 09:40 PM
capearbor
10-10-2005 10:00 AM
