Will not run
Just put in new motor a month ago and was running great till I run a yellow light speed up to go then it just cut off I checked the fuel it is geting gas It is getting fire. but will not start it will start if I spray starting fued in it then cuts off run a hot wire to the fule pump and checked the inlet line gas is coming in and the return line gas coming out but no start unlessI spray starting flued in then it starts right up but only runs till it burns outI do not think the Injectors are working is it the PCM or what.??? HELP!!!!
harleypower69
02-20-2021 07:45 AM
jcoll72305
01-24-2013 10:45 AM
