body repair
Sl2 is the car i wish to repair. Its the quarter panel behind the door primarily that needs attention. Can i remove the skin?
Ive been swamped with other projects, so it is low on the priority , but one i will get to in the coming month
The paint itself was not scratched,however the panels cracked. Front fender light on the door, and rear 1/4
from what ive been told the quarters are only bolted on so itd be easy to do them though the spot behind the door you either come from under the car to push it out and repair from there or depending how far after the door you can pull the interior piece and do it that way, it sounds like you should be able to do it without having to remove much, if i had a pic i could describe better.
ruggercards
11-20-2008 10:38 AM
