1995 SC2 Engine Removal
Old 02-06-2013 | 05:58 PM
floodx4's Avatar
Default 1995 SC2 Engine Removal
I was wondering if anyone could point me to some good resources for engine R&R on a 1995 SC2 DOHC.
I have pulled several motors on RWD cars in my life, but this will be my first attempt at a FWD.
Just wondering if there are any good videos out there, and what manuals would be the best to get before starting the swap. (Chiltons, Haynes, or other service manual).
This will be just a straight swap due to original motor seizing.
Is it best (easier) to pull the motor out from the top, or should I drop the cradle?
Are there any specialty tools I will need, other than standard shop tools, and a cherry-picker?
Any other advice you would give to a Saturn noob?
Any and all help will be greatly appreciated!
Old 02-07-2013 | 09:20 AM
Wish I could help you man, but I've never done a Saturn. I do know that on the FWD Mopars, it's easier to drop them from under the car. No cherry picker needed, just a good hydraulic floor jack and jack stands.
Old 02-08-2013 | 10:42 AM
pm octavious -- he just finished a rebuild not too long ago -- I believe it also included a trans swap
Old 02-12-2013 | 01:18 AM
Here is a place to start sorting through in this forum
https://www.saturnforum.com/forum/se...earchid=263704
Old 02-13-2013 | 12:16 PM
I had just wrote out a whole nice description of what to do - and the page refreshed............
Now I gotta go to class but ill write it out again later hahaha
Old 02-15-2013 | 11:20 AM
Okay ill just write alittle andif you need more help feel free to message me
The haynes manual will be of good help. It is easier to pull the engine from the top unless you have the car lift and all the stuff to lower the cradle properly
If you do pull the engine from the top though, use a load leveler! I didnt and broke my power steeping tank and messed up where the hood seal goes
fordman
12-30-2012 02:44 PM
wcrise
03-09-2010 09:49 AM
Timmn1
Engine & Internal
01-04-2009 12:27 AM
jwlane
08-02-2007 11:22 PM
dye5150
12-12-2005 08:01 PM
