97 SC1 fuel pump will not run
Hello, I have a 97 SC1 that the fuel pump will not run on. The fuse is good, and there is power to one contact of the fuel pump relay. Does anyone have a good wiring schematic of the fuel pump circuit or maybe has had trouble before that was an easy fix? I have replaced the relay and that did not correct the problem. [img]smileys/smiley6.gif[/img]The Haynes Manual I have is no good. Thanks, Doug
harleypower69
02-20-2021 07:45 AM
jcoll72305
01-24-2013 10:45 AM
