98 sc2 missing
Old 04-01-2007 | 05:25 PM
chamberland_666's Avatar
ok so i just welded up my exhaust back to my manifold cuz it was broken off (dident go far open) adn then at the same time put in my cold air , i take it for a test ride and check the plugs and there white ...so i take off the cold air since it is still a little cold here thinking that was it... check the pugs again and there still white so i clear all the codes thinking the computer dident ajust yet , that dident work ...then i noticed i was criticaly low on gas went and put sum and it stillll misses ..and the engin lite wasent on...
can any one help me ?
thanx joe
Old 04-01-2007 | 06:05 PM
ducky's Avatar
If its an engine miss there are several things to do; depending on the age and mileage you can remove the coils and clean up any corrosion with sandpaper since the the frame is grounded through the bolts, wirebrush the bolts, if the plug wires are old they may need replacing, use dielectric grease in the plug boots to prevent future corrosion, lightly coat the bolts with regular or dielectric grease for corrosion prevention also. Clean the throttle body inside and out with carb cleaner especially the linkages to free them up. The plug gaps should be 0.040 inch/0.02mm(?). Have you checked the two-wirecoolant sensor for a cracked tip leading to all sorts of engine running problems? The original coolant sensor(ECTS) is resin tipped and the replacement is brass and is a must-do repair! Look closely at the two-wire connector for any corrosion and replace it if necessary, one from a junk yard taken from the air temperature sensor wiring or from the dealer.
kens
09-21-2009 01:52 PM
BRG'sFSTSL1
05-19-2008 07:55 PM
lomfs24
06-02-2007 12:38 AM
Briad
02-20-2007 04:08 PM
tiny747
10-29-2006 07:52 PM
