anybody know how to boost fuel pressure?
Old 08-19-2009 | 09:40 PM
gtokidd's Avatar
Default anybody know how to boost fuel pressure?
i have a 99 sc2 that i turbo charged. i got bigger injectors but i need more fuel yet. does anybody know a easy/cheap way to get this done?
Old 08-29-2009 | 08:02 PM
So you added a turbo, you added high flow injectors, you have done all that work, but you have no idea how to go about bootsing fuel preasure .... ok then..
Old 09-13-2009 | 08:59 PM
99turbo's Avatar
dont worry about it buddy i got it.
Old 09-14-2009 | 12:58 AM
JMuse84's Avatar
There is a few ways to do it. but you cant just throw a turbo on a car and throw injectors at it and expect it to give you the fuel you need. You can run MS2 which can be very invasive. You can also get a Rising Rate FMU which cost as much as MS if you get a good one. Or run Auxiliary Injector System which is kinda a crude way to do it. [B]Go get you a Vortec FMU ( 10:1 ratio works good on mine), a decent Fuel Pressure Regulator, a 1-3 BAR MAP Sensor, Walbro 255LPH Pump or equivalent, Set of RC Injectors (500CC or depending on your app.), Take your car to have it tuned ( or send your ecu in with all your specs boost pressures ect). If you half *** it, you will be doing it again. With much more costly consequences.
dwd375
07-29-2015 11:35 PM
timmerz
01-01-2013 12:51 AM
timmerz
07-07-2011 07:28 AM
FranconiaFriend
04-27-2009 10:45 PM
crhammondusn
06-10-2008 07:14 PM
