Blower motor won't run
Hi, I have a 1999 SC2 and the blower motor will not run at any speed. I have checked the fuse, replaced the relay and resistor, ran a couple of wires from the motor to the battery and the motor worked. There is power at the blower motor and it if I turn the switch off the power goes away. Everything seems to be working. Have I missed anything to test?
RE: Blower Motor Questions
I suspect the return lead in the regular wiring harness from the blower motor back to ground connection point is defective.
tikidude
08-30-2014 06:04 PM
